1801 Ford Diesel Industrial Backhoe
Went to buy this today.Big issues. Seller started up and drove forward a few feet, heard a loud popping/clunking sound coming from left side of rear axle. WE asking seller to raise bucket/hoe slightly shut off engine and leave in neutral. Two of us pushed machine a few feet, same thing. Any ideas??
Could be anything from loose wheel nuts to a damaged ring gear,take the weight off the wheel and with a long pry bar see if there is any up and down play,the outer bearing may have failed,with a machine that age anything can have let go.
AJ
(quoted from post at 03:27:47 08/26/19) Could be anything from loose wheel nuts to a damaged ring gear,take the weight off the wheel and with a long pry bar see if there is any up and down play,the outer bearing may have failed,with a machine that age anything can have let go.
AJ
both sides of the axle housing where it meets center section are rtv ed i asked the seller, got schultzs response
