310 crawler
taylbone
New User
I'm looking to see if anybody knows the dimensions of the spacer that goes between low and rev and second gear on the main shaft for my late model 310 crawler i can't find one so i will have to make it any help would be nice
You should include all the info about your crawler identification, not just say late model. There are a number of 310 models (letter designations) and serial number breaks within those for the parts catalogs on line. To find the right one, you will need the full model info and serial number for your crawler. In the parts catalogs some transmissions show part number 35130 changes to 51200226, for the spacer I think you are looking for, and some show NLS (No Longer Sold).
Have you checked with your local Case construction dealer?
Have you done a web search and checked with any salvage yards that show they are dismantling 310 series crawlers?
Try a post on the Case and David Brown Forum, someone over there, who doesn't follow this forum, might have an idea.
Thanks the ser# plate is not on my machine i'm pretty sure it is a 310G i got no info from the case dealer in Charleston thanks again
Are you familiar with the CaseCE parts catalog site? You can study the options there. Some of the 310G transmissions used the part number I posted, some of the 310G transmissions show the spacer is No Longer Serviced. They also show transmission serial numbers for some. Does your transmission have a serial number on it? Look for engine, dozer, loader or any other serial number tags, they might help shed light on a closer ID.
You might try contacting Coleman Equipment Inc. in the Kansas area or Beauregard Equipment in Colchester, VT. Sometimes different parts people can shed light on things others can't. Some seem to be able to find obsolete parts.
