trak
plan on looking at one for sale tommorrow, was wondering if anyone knows if its realitively feasable to add onto the hydraulics for a jaw bucket. ty
A trip to a construction rquipment salvage yard should yeild the necessary parts to add a third valve section to the valve stack and the necessary tubes and lines. you might get lucky and the tractor has the third valve already in the stack but the handle and lines were never installed
on my 941B with a 4in1 bucket the lever for the jaws is definitely set a distance away from the other two--leading me to believe it is a separate valve assembly
Putting on the 4 in 1 bucket is the easy bit,knock out the four pins of the standard bucket and mount the 4 in 1 if your machine has a spare valve it then only a matter plumbing it up,if it does not have a spare valve then you will have to add an extra valve, what equipment is on your tractor,does it have a ripper,what is the serial number?.
AJ
