Hough HA loader
orland
New User
Can anyone help me out with my Hough HA?
It has a 35 hp Waukesha diesel. I Bought it not running which I got to run now, but I think it's the torque converter that leaks like a sieve and I can't move it. Where can a guy find parts for these things? I would appreciate any advice.
Orland
First thing I would do is establish where the leak is coming from,check all the hoses and anything external that could leak,if the oil is is coming from the torque housing you will have to remove it and find the leak in there,I have seen the output shaft seal gone,housing o'ring even seen them cracked so it's not a thing one can guess but make sure it's from the torque housing that is leaking and not just running down off it from something external leaking over it.
AV Fun
AJ
Thanks AJ.
I have established that the leak must be internal in the torque converter. It leaks so bad that I had to
place a pan under it. If I take it all apart,can I get any parts is the question.
Orland
there is a publication called "The Parts Book" which contains heavy equipment vendors from coast to coast. Soon as you find out who built the trans, the transmission people in the book will figure out the rest.
Take the drain plug out of the torque housing and see if you find anything else,I am thinking the drain plug from the torque may have come out,worth a look.
AJ
