deepsouthoutdoorsman
New User
I have a new to me 450C loader. I bought it knowing the hydraulics are weak. Boom wont even lift unless at high rpms. So I purchased a pump for it thinking it was the pump. Same thing. No hydraulic pressure. Every control is the same way. So I drained the tank. New return filter. Cleaned the suction screen. Refilled to half way is sight glass. Still same thing. Weak pressure. I removed the pump again and checked the coupler splines and they are good. Is there a Main releif valve on the system they may be stuck open not allowing any pressure to build? If so where or which valve body would it be in?
