Hi all,
I finally have put to use my aging Allis-Chalmers HD-4 crawler with loader bucket. It works great except that ocassionally the right track seems to get a little lost and will not track the bottom rollers as it should. At that point it goes "pop, pop, crackle" and makes really bad noises. I ususally back it up slowly then and the track finds its way home again. It always happens after making some agressive turning involving the use of the steering brake on that side. Not sure why as the right side is the "good" side. I rebuilt the idler wheel axle and bushings and all the bottom rollers are good on that side. Left side is far worse for idler wear but the track always runs true on the left side with no issues.
What do you suppose is going on?
Randy
Randy
