DVrepairman
New User
I have a friend with a Case 480E backhoe that suddenly lost power steering. With the engine running the steering wheel turns easily right and left but it doesnt move the
front wheels. If you lift the front wheels off the ground and turn the steering wheel the front wheels barely move.The valve at the bottom of the steering column has 5
lines coming out of it. I assume one is pressure,one is return to tank,one for right ,one for left but Im unsure about the fifth...a drain possibly? Does anyone know a
test proceedure to determine if its this valve or if it has a seperate power steering pump that may have failed? Any help is much appreciated. Thankyou!
