Company Logo Shop Now
TractorLinks.com
Re: Ford 555B backhoe front axle assembly
Check Break
07-14-2019 16:17:23
You can see the T/C through the inspection plate under the bell housing. Pull the drain plug on the bottom of the transmission case and the plug out of the T/C. You'll have to bar the flywheel around until you you see the T/C plug. When she's drained, change the filter and fill her up. If the T/C is turning before you drain the contaminated fluid, chances are you will be able to circulate new fluid throughout the shuttle. If a valve is stuck, it might free up with a dose of new fluid. If not, there's two valves on top of the oil divider that can be checked before you split her.
If I were you and could find a flame cut 2WD front axle, I'd convert her to 2WD and keep her that way. Unless you're working in mud, you don't need 4WD.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
