Company Logo Shop Now
TractorLinks.com
Thomas 105 Skid Steer
RICH NY
07-10-2019 15:41:19
My Skid Steer with 330 hrs. has started to overheat when used over a half hour. I have blown out the cooling fins and replaced the thermostat, yet still overheating Kabota engine.Any ideas?
AJ.
07-12-2019 18:54:56
 Re: Thomas 105 Skid Steer in reply to RICH NY, 07-10-2019 15:41:19
I took it wrong when I thought you would have checked the fan first,surely you can see whether the fan is cutting in or not,if not put the wires together at the switch,if it cuts in then the switch is faulty.
AJ
AJ.
07-11-2019 06:42:42
You may have a blown head gasket or the rad blocked internally,I take it that the fan and fan belt are good,if you have a heat gun check the top and bottom tanks of the rad when the engine is hot and running,there should be a difference between 10 and 12 between the top and bottom if the rad is doing it's job,if not try back flushing it,take off the bottom hose and stuff in a water hose with a lump of rag,with the cap off turn on the water supply,flush it till the water comes clean,to check the head gasket,remove the fan belt,check the pump is good,fill the rad to the top,start the engine with the rad cap off,watch the water in the filler for air bubbles,if you get air bubbles it is caused by compression leaking into the coolant indicating a failed head gasket,cracked head or or the like.
AJ
RICH NY
07-12-2019 12:44:25
 Re: Thomas 105 Skid Steer in reply to AJ., 07-11-2019 06:42:42
I believe this Skid steer has 2 Electric cooling fans. I'll have to check their fuses/operation. Thanks for the reply!
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
