Company Logo Shop Now
IH T-340 Hyd question
jsborn
06-28-2019 17:38:49
I have a IH T-340 with 6 way blade and the Hyd system seems to be getting really slow and noisy. Sounds like possibly air in system.
I looked in Operators Manual and can't find any filters or screens to clean or replace.. are there any??
Also how do you check correct fluid level in system ?
All I have is operators Manual so if any one has a Maintenance Manual in PDF format that they might share I would be grateful.
Thanks in advance
jsborn
07-25-2019 05:36:24
 Re: IH T-340 Hyd question in reply to jsborn, 06-28-2019 17:38:49
Cleaned relief valve screen and installed new filter, NAPA 1469 filled with fluid to top off what I lost approx 1 Gallon and system works like new.
Thanks to all who helped and talked me through this problem.
jsborn
07-24-2019 04:48:23
Finally got time and weather to take side plate off. Found the filter is the new style and totally stopped up. The screen on the relief valve was totally covered also. I went to NAPA and ordered new filter and will install tomorrow if weather and time permits.
Thank you all again for all your help with this.
Jim.ME
07-07-2019 05:12:34
You may have to actually log into Classic to see it. I don't see those send email buttons unless actually logged into the Classic view. Not logged in it shows as no email.
jsborn
07-07-2019 05:02:43
I thank you for all you help but i have looked in classic view and morden view and both say no email available. As I am sure I will have more questions please send me an email so i can get yours.
Thanks my address is: farmshop912@gmail.com
Jim.ME
07-04-2019 08:18:26
The "send email" link at the lower right appears in the classic view, doesn't show in the modern view.
jsborn
07-04-2019 05:10:30
Don't see your Email address so please if you don't mind I would like Part Numbers and any other info you may have.
Charlie
07-04-2019 07:49:16
 Re: IH T-340 Hyd question in reply to jsborn, 07-04-2019 05:10:30
The newer one piece filter is available from NAPA as NAPA-1469. The old donuts to fit in the old metal case were NAPA-1139, or WIX 51139, or International 375085R91. You should be able to send me direct emails by hitting the "send email" link on my post, lower right. Then if you needed further info in the future, I could provide it through my permanent email.
Charlie
06-30-2019 09:59:18
Filter is the most common issue. Wehn you open up the hex cover, you may have the old style: metal cage with 2 donuts to replace. There are newer one piece disposable units. Email me if you want numbers. dipstick is under right floor panel. Filler plug is on left side.
tomtinker
06-28-2019 18:14:49
If it is like the tractors it has a hexogen shaped flat plate on the side with the filter under it.
Copyright © 1997-2020 Yesterday's Tractor Co.
