I finally understand your post better. Service manual describes swivel and other items you described. The brakes appear to be releasing. There is 8400 hours on excavator. Operator is about 60 and says from experience he feels this machine has been ran hard. It has a service sticker with no info except it was serviced at 8000 hours. They have put less than 50 hours on it and Operator describes "power" in the hydraulics has steadily been getting worse since they bought it.
I'll look at swivel. If a internal sealing ring is blown it may only be observable by taking apart I expect?
If main pump pressure reads low if I understand correctly, there could be internal leakagebypassing in a variety of components. I was told the main relief valve will be by swing motor? So still trying to figure out where the main relief valve is. Maybe its being held open by a piece off brass filing?
The boom will not lift if boom and dipper fully extended with bucket full. Operator said he would have to empty bucket by 1/2 to get boom to come up so maybe packing in boom bypassing?
Operator said machine does not have the power he would normally expect to "stand the machine on end". He though dirty filters or a weak pump may be the culprit yet I found out pump is ok.
He said excavator would travel fine straight or in reverse. Yet when going to turn it would turn very slowly and not quickly. It seems by the operators opinion machine struggles to turn when forwarding one track and reversing the other, and when using boom when fully extended with dipper.
There are five hydraulic filters (all new filters ordered):
Pilot drain filter. It is a small paper pleated filter and was very dirty with super fine black substance. Washed out 7 times with gas before it came cleaner.
Nephron filter. Appear to be made of card material and looked collapsed inside. I learned this may only filter 3% of hydraulic oil at a time during operation.
Drain Filter. A spin on filter beside hydraulic tank. It appeared to be full of rusty water. About the size of a regular v8 engine oil filter.
Return filter in tank. Brass filings were small but easily must of passed through return filter. It appears to have a metal screen around it and possibly pleated inside with fine screen material? I haven't cut it open yet. Operator said he checked it last fall so maybe brass filings fell into tank then??
Suction filter. Held in bottom of tank with a spring loaded ready rod. Appeared not to bad except for brass filings in outside of bottom pleated edge area.
The guy that runs the machine is older than me and wanted me to check filters first. They were all dirty. I pulled suction filter up out of tank and it was filled along bottom pleats with brass filings. Shop in town told me pump would be good place to check for brass wear and tear. So I took pump off engine and shop checked it all out and its fine. Brass filings could be from an earlier pump failure because I noticed pump had color coded wires on it from a past mechanic when is was owned by someone previously. Yes the pump has other items attached to it so I expect larger section is for excavator swing, boom, dipper, and bucket. Other sections for track travel. I'll be going to put pump back on engine along with new filters, and clean out tank. Then I will tell operator I will be completing the two travel motor and swing motor drain tests as outlined in manual. When I pick up pump I will ask about sections of pump and purpose. I will clean out all suction lines to pump. I want to thin out remaining hydraulic oil with a non flammable solvent or cleaner and then suck it out. Any suggestions to thin out oil and suck it up with a shop vac? I'm thinking shop vac my light up! I drained the 25 gallons in hydraulic tank and definite black tinge to oil as it sits in buckets.
I will ask about these fittings on pump yet thought you may know what fittings these are for and the name of the type of fittings they are. I have a bucket of misc hydraulic fittings. I bought two oil filled gauges and a ball valve with hose to check pump pressures. I don't have manual with me but one gauge is for testing main pump and the other I believe for track motor tests.
The manual refers to the fittings on pump as "JIS B2351 0 type". On the net they look like a fitting that threads in with a sealing o-ring on base of threads.
I'm wondering what these 2 hex shaped caps are for on main pump ports, and this male fitting that resembles a male hydraulic fitting for a female fitting to quick-couple to it yet don't know what fitting type its called. The hex caps are approx 15 mm (15 mm wrench fits best) and the male fitting measures 12.8-13 mm in dia., and 16.4 mm long approx.
I expect one of them may be the air bleed port?
