580c case banjo bolt
Jdtractor121
New User
I'm missi,g a banjo bolt that goes into my injection pump holding the side fuel line on. Does anybody know where to find a replacement? Case said they cannot get the part as it's concisdered "counstruction equipment" I've called 3 different case dealers. S
Case 580C, 207 Case engine Roosa Master Pump, I had trouble locating those banjo bolts before because there is a mistake in the parts list,the said banjo bolt connects the injector line to the pump the Case part # is 73613 bolt,the sealing washers are 2 x G49407,the sealing washer specs listed is 9.63mm ID x 12.83mm OD and 1.65 mm thick.
AJ
