bfullmer
Backhoe sat all winter-started up ok then started sputtering found water in fuel tank -drained tank and replaced filter and bled to pump now no start- won't even fire on starting fluid-what happened ?
It won't even fire on starting fluid because it is getting no fuel,an engine will not run on starting fluid alone,has it got the manual or electric stop,the metering valve could be stuck in the stop position,you have cleaned the fuel system and replaced the filters and bled the system,loosen each injector line at the injector and crank the engine over till fuel spurts out,tighten the lines and try for a start.
AJ
