Hello,
Having Issues with a I3500 Backhoe. Has the D239 Engine and the Bosch Injection Pump. After sitting for about 5-Years I'm trying to bring it back. After getting new filters and fuel in it and replacing the return line off the injectors I got it fired up. The issue I'm having is that no matter where the throttle linkage is on the Injection Pump the machine will only idle. I get a little more RPM out of it if i out the Start/Stop/Run Fuel lever on the pump from Run to Start. Do I need to get into the injection pump? Any thoughts on what I'm missing?
I bled every fitting on the fuel system multiple times and let it idle for over an hour with no change in performance.
Thank you
-Jesse
Thank you
-Jesse
