1085B Cruz air
The throttle is fluid operated (like a car brake)with an electric lock,check the reservoir for fluid,if empty fill it and bleed it,press the pedal down and use the electric lock to hold it down to use the back hoe (switch on dash),the stabilizers are electric operated,check all the fuses,if there was ever a machine that you need the operators manual for you got one now,they are not conventional in any sense of the word.
Good luck with it
AJ
AJ is on it. They were good units in their day. All the controls go down through the swivel. There is an electric swivel and hydraulic swivel. Could be an air swivel also unless I have my models confused. All can be problematic with age and lack of maintenance. You will need the manuals. Case construction dealer
may be some help. Good luck
Dennis
(quoted from post at 17:01:12 04/13/19) Does any one know anything about one? I bought and the
outriggers don't work , don't have any throttle
Had a few of them
Try cleaning the electric swivel
We always had a can of tv tuner spray that worked great
I doubt anyone markets tuner spray any more but should be easy to find out what it was made from.
