Charlie175
Transmission question.
Operating 1st and reverse work as normal (Well with 50+ years of wear). I do have a whining noise when using these gears.
2nd and 3rd seem very tight as I guess they get used rarely. I have noticed that if I use 2nd/3rd, going back to 1st/reverse it is very hard to select. It seems the rail is out of alignment after I move? I had to remove the shifter once to get it to go back in gear. I think there is a spring and ball there to keep in in line? Maybe that has stuck or broke?
