1010 John Deere Crawler steering problem
Rob03
I finished putting in new steering clutches and brakes. My problem is that the right side steers fine. When you pull back on the left steering lever the crawler stops moving, left of on the steering lever and it will start to move. I checked all of my adjustments per the manual and everything is correct. What did I do wrong or is something slipping. Thanks in advance for any help.
Robbie
Sounds like the right steering clutch is slipping. It has to drive when you pull the left lever. Did you adjust the fingers of the steering clutch pressure plates with the gauge when you assembled the steering clutches?
