TD15C Dresser Fuel Pressure
Powerram250C
New User
I?m replacing the fuel filter restriction gauge and would like to know how much pressure the lift pump on the back side of the injection pump puts out
under nornal conditions. I know as filters get restricted, the pressures will go up. I guess I need to know what maximum pessure it can put out for getting
a correct pressure gauge. Thank you.
As the filters get dirty the fuel pressure drops, that is why the machine looses power
Should be around 40# and with a non stock gauge it will bounce around with each pulse of the transfer pump
