Caterpillar track rollers
ihcarl66
Trying to grease bottom track rollers on d69u. 3 have button grease fittings 3 have bolts when I take bolts out and try to put button fitting in bolt hole the hole is to big are these rollers oilbath instead of grease
Looks like you got one or each going by the pictures,there is a special nozzle needed to fill the oil filled rollers,that undercarriage looks to be well worn,the roller in the second picture looks like it loose,there is a crack in the link rail in the first picture you should have it welded before it breaks right through the link,there is not a lot of life left in the undercarriage.
AJ
looks like the rollers are worn also--the roller flange is wearing into the bushing boss on the track links
