I have a Case 580 construction king TLB with the gear shift on the right hand console. I tried moving some snowbanks today and it seems to shift in and out of gear.
However if i raise or lower the bucket at certain points the tractor will start moving again. I checked the oil on the dipstick in the floor behind the seat (in front of
the backhoe controls) and that level is where it should be. I assume the tranny fluid is low but am not sure where to check it. Is there a panel or something under the
vinyl flooring or another tube somewhere were i can check the level and top it up?
