what is digging depth of Case 580 ck model 33 hoe
marlin54
I would like to know what a case 580 ck about 1971 with a model 33 hoe. its not an extend hoe. I looked at tractor data and the best I can understand it says there is 2 models .. a case 14.5 with 257 inches or 21.4 ft. and a case 16.5 extendahoe with 265 inches or 22 ft. ..so what is the case numbers 14.5 and 16.5 mean? and is the model 33 hoe the only hoe for the years of 1966 to 1977 ?
Go to: https://www.casece.com/northamerica/en-us/resources/prior-models . That site has spec sheets for the older machines. The models from the first 580s on are there so it may help you with the info you are looking for.
Std 580CK will dig a Max depth of 14'5" and extendahoe with dig 2' farther this chart should help you out, from 580CK lit, as for your question on the 33 being the only backhoe made those years the answer is No but it was used on a few different machines like the 480
