I picked up a Ford CL65 skid steer this weekend. The engine starts and runs fine. The pump and all hydraulics work fine. It moves forward and reverse fine. However it's very old and hasn't had a lot done on it so I'm looking for advise.
1. I have no manual or service info. I can't seem to find anything online either.
2. There doesn't seem to be hardly any info online for this unit so I'm worried I will not be able to find parts.
3. It leaks hydraulic. It's coming from directly under the middle so I'm thinking it's the pump, but I'm not sure.
4. The hydraulic hoses are very worn. The outer rubber jacket is cracked and peeling off all of them. Where do you get hoses? Are they universal or tailored specifically to the unit? Are they expensive?
5. It's hard to start when cold. The guy I bought it from used a puff of starter fluid. It has glow plugs but the guy didn't know how to turn them on (or what they were for).
6. There's some off modifications to this unit. The start switch is in an outdoor electrical box that obviously wasn't original. The engine radiator has been installed on the roof above the engine with a 12V always on fan. It blocks the line of site when backing up. I'm thinking this needs to move.
So basically I'd like to get some information on the unit and some general advise regarding what I should look and and what almost certainly needs to be done.
