I've had a log get serious with the tilt hoses on ours, including wrecking one of the fittings to the pipes beside the radiator. It has been "farmerised" and the one good one is a JIC flare that appears to have had the nut expanded. And it has been sealing on the outer rim of the flare. The screw nipple feels like it should seal in the centre of the nipple - I can't really get a look.
The parts book doesn't give fittings or type/dimension - only a made-up hose.
So I have 14 tpi, somewhat bigger than an SAE nut, not flared and seals in the centre of the nipple by the feel.
The nipple is 22.5 mm diameter over the threads.
5/8 BSP looks a possibility? Apparently common on European machinery. And our supplier who would know is closed for Xmas/New Year.
Anyone got any more info?
TIA
Ian
(Also posted at Unofficial Allis)
TIA
Ian
