MF 200D drive problem
bannerlane
New User
Does anyone have experience of the MF 200D crawler, which I believe differs significantly to the other 200 models? The drive on ours has become intermittent. We think it could be a blocked transmission oil filter but don't know where to find the filter!! Any suggestions gratefully received.
Many thanks
I was looking for something else recently and happened on a post about a 200 transmission where the guy stated he had to remove the belly pan under the tranny to access the filter which he said was on the side of the tranny,I don't know if it's there or not,your problem would be more likely to be the suction filter than the pressure filter,that would be the strainer on the oil pick up been restricted and it would require you to drain the oil to access it,they are usually washable.
AJ
(quoted from post at 04:13:54 01/07/19) I was looking for something else recently and happened on a post about a 200 transmission where the guy stated he had to remove the belly pan under the tranny to access the filter which he said was on the side of the tranny,I don't know if it's there or not,your problem would be more likely to be the suction filter than the pressure filter,that would be the strainer on the oil pick up been restricted and it would require you to drain the oil to access it,they are usually washable.
AJ
Many thanks. We'll have a look.
