Hector Gemme need AC parts information
wilson ind
Sir I need information where to buy Allis H4 bell shaped radiator hose. part numbers 245105 1-1/13/16 , 245747 13/16 to 1-1/2. and 249803 -1 13/16 to 2 3/4 this 90 degree hose. Also my radiator pressure cap has been replaced with loose fitting non pressure. What pressure in normal cap.Thanks any help bill wilson 812 699 0011
Where have you tried? Have you tried www.minnpar.com?
The radiator cap shows as part number 0245891-5 (supersedes 0245891). Add a 7 in front of the original number for the later AC part number, 70245891 and there are a number of aftermarket ones on eBay that may fit. It looks like it would be a 7 psi cap which is similar to the AC tractors of that era. You might try an AGCO dealer to see if those hose numbers and radiator cap number still appear in their system by chance.
Thank you sir I did find via a good O Riley parts man that the ac hose parts number relates to a
gates number and is available
