Evening: Sent the injector pump off as you knew i would have to..
shop discovered the ring in side had failed and pieces everywhere, the high pressure side was good
just the governor section needed work other than seals,gaskets as per normal.
All back in place and runs/powered like a good but old machine should be.
The trick of loosening the timing cover..? does that apply to any injector pump, that it would
speed up when loose and slow down when tight.
What was really nice was that they sent extra free sealing washers for the high pressure lines..knowing
i was going to lose 2 of them....
Tks for the help
Tks for the help
