Has anyone out there ever adjusted the hydraulic pump pressure? I may need to increase the hydraulic pump pressure on my case 450 loader. I have a brand new pump and I put a 4 in 1 bucket from a case 455 on it. The original bucket was an 8/10 yrd. bucket and the 4in1 is 1.25 yrd. It is a LOT heavier than the original. I would rather increase the pump pressure just a little,(not a lot) rather than increase the lift cylinder size. Or I could just load the bucket lighter, which I would probably do if things don't work out. Just was kicking the idea around if it isn't a big deal to increase the pressure a little bit. This is my real work horse and is the go do machine when I need to get things done. thanks Phil
