Top radiator tank for CAT 930
RedMF40
Hello, all--I'd like to reclaim the top part of the radiator with the caterpillar logo as a keepsake/industrial art. I have permission for this, and some money is involved. My question:
Is that top part just a cover or is it part of the radiator? I'm guessing that if it's part of the radiator, then the whole radiator needs to be removed--unless I got at it with fire.
Thanks for any help--I'm sure someone here knows what they're looking at.
Yes the top tank is part of the radiator,the radiator core will unbolt from the top tank when you have all the bolts undone,I can't remember if you can get at them all without lifting it up or out and there is a lot of them in it including the sides.
AJ
(quoted from post at 09:09:08 11/13/18) Yes the top tank is part of the radiator,the radiator core will unbolt from the top tank when you have all the bolts undone,I can't remember if you can get at them all without lifting it up or out and there is a lot of them in it including the sides.
AJ
Thank you. I'll likely make an offer on the whole assembly, may even make the radiator functional again as part of home heating system. Provided no leaks. Thanks again for the help.
Was that old girl burned out it looks like all the paint has been burned off,they were a good loader back in their day.
AJ
Yes, my first thought was the tractor had burned up. But there are some wires and rubber pieces remaining that don't look scorched. Don't know why it's so rusty, maybe just from sitting for so many years.
