I wonder if you would check me on this item...1985 410B TBL: Looked at the JD parts site and it looks like to remove the injector pump, I remove a 2 or 3 inch? plate of front side of the pump mount, unscrew a nut and by removing the two mounting nuts at the pump front, side it rearwards off the studs and out of the drive gear?
First put the flywheel locator pin in place for # 1 cyl at TDC, ensure alignment marks are located and known at the pump mount flange, and the drive gear teeth are marked/aligned, the pump shaft has a keyway to fit the drive gear?
No power to move/dig and surges at full speed in neutral, 2000rpm and up is slow to gain, filter and injectors are new, lift pump steady flow, and starts easy when hot, local shop says gov section needs a rebuild, so off it goes.
tks
tks
