Dresser dozer will not turn
Alex1423
New User
I have a 1976 dresser TD8 dozer it will go forward and in reverse but will not turn left or right. About 30 minutes later the brakes went out. Need help. 423-290-4107
Thanks,
Alex
As PB said check all the linkage is functioning and moving the respective valve,if that checks and the oil levels are correct check the suction strainer and pressure filter as it sounds as if the booster is not working and both sides failing at once indicates a common cause,linkage or oil pressure.
AJ
