Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Gehl 4500 Skid Steer Stalling Out/Hard Starting
Author |
[Modern View] |
r8f1k
10-12-2018 09:20:23
This message is a reply to an archived post by r8f1k on July 24, 2018 at 19:20:06. The original subject was "Gehl 4500 Skid Steer Stalling OutHard Starting".
Still having trouble with my Gehl 4500. I installed an electric fuel pump to alleviate any suspected vapor lock issues, set the regulator to 4.5 PSI. The issue that I still get it that the engine will stumble for 2 seconds and die when a slight load is applied. It can happen during turning, lifting, dumping, but so far never when driving in a straight line. If you catch it stumbling fast enough, you can throttle down and save it from dying. Then slowly throttle up and she will be good for a while. It is a very difficult situation to be in when you need a machine to do it's job. I have good spark, engine runs very nice, no misfire, spark plugs all have a nice even burn on them. Ford 1.6L Industrial, Zenith carb. Not sure what to do, I am very frustrated. Could I have a bad or going bad vacuum advance?
pinball
10-13-2018 09:21:43
Re: Gehl 4500 Skid Steer Stalling Out/Hard Starting in reply to r8f1k, 10-12-2018 09:20:23
I had the same thing happen to me on a skidloader that had an electric fuel pump same for motor. after checking several things I finally took the suction line off the fuel pump and blew real hard back through the suction line. problem solved but every so often I still had to do it. just never did drain the tank completely and flushed it out. your pressure is more than you need. I put a 2.5 psi on mine. to much pressure will effect the needle valve in your carb. I also installed my pump below the radiator so its not far from the fuel tank. check the filter on the suction line of your pump. mine plugged up once. good luck
r8f1k
10-13-2018 05:50:15
Ok, so I think I may have narrowed this down. Perhaps someone with more knowledge could help. When I bought my 4500 it had an old hydraulic filter housing, very large and aluminum. It leaked poorly because the matting surfaces were scared by screwdrivers and chisels by who ever had this before. They also needed LOTS of RTV to keep it sealed up. So I replaced it with a Prince FA1300-00 Filter Head, Cast Aluminum, 25 psi Bypass Spring, 20 gpm. It is running the Hastings version of Princes' FA10 filter, 10Micron. Is the filter and housing too small? Is the filter too small? Are the PSI/GPM ratings wrong?
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Fast Shipping! Most of our stocked parts ship within 24 hours (M-Th). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a company you can trust and have generous return policies. Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ About Us ] |
Home
| Forums
Copyright © 1997-2018 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
