smadjuster
New User
Hello Everybody, and thanks in advance for your advice.
A total newbie to tractors here. I am in search of a project backhoe. I ran across a 1960's Case 530CK that was caught in a grass fire. All of the tires burned and the area from behind the steering wheel to the backhoe controls appears to have received most of the heat. Some of the backhoe cylinders are a little blued from the heat and the backhoe control valve body got pretty hot. The machine has a 188ci diesel engine that appears okay. The oil is a little gunky and the engine will turn over, but obviously won't start. The fuel injector body got hot and the exterior portions of its seal/gaskets have melted a little from heat, but don't see any other exterior issues with the engine. The gearshift (a single shaft with one knob - please tell me what type of tranny this is?) is rusted in place and will not move at all. Obviously, all of the cylinders and valve bodies will require rebuilding, along with new hoses, etc. In addition to tires, this will likely require wheels, too. I figure that before it is all done I will replace every valve, gasket and seal on the thing - IF I take it on. Not knowing what kind of tranny this is, I really don't know what to expect inside, and the hottest part of the fire appears to be between the gearshift and the backhoe control area. Maybe somebody can tell me what to expect from a tranny box that got hot?
I can get it for about $500, delivered. I'm not at all afraid of a challenging project, but not interested in a lost cause. Run or take a chance at it? Parts available for this thing?
