jd 410 loader/backjoe
glenn5370
New User
am working on jd 410 backhoe w/shuttle shift.
has no reverse or netrual. changed filters and hyd. oil, ckecked shuttle valve body for debri still does not work . have forward but no reverse
Likely cause is that a disc in the forward clutch pack has broken up and sandwiched it self between the discs causing forward gear ito be in drive even when the lever is in neutral,when you select reverse is it bogging down the engine,if it is stop trying it because it is engaging forward and reverse at once,nothing for it but to repair the shuttle.
AJ
