allis h4 rear sprocket seal relacement
pinball
I have a rear sprocket that has a bad seal and needs replaced. ANYONE ever replaced that seal. thanks norm
The memory is rusty but I think the track has to be taken out of the way,the sprocket is taken off,the shaft comes from the inside out,ie it is secured on the inside accessed through the steering clutch housing, I cannot remember if the clutch is in the way it was back in the sixties I done the last one,I have a parts book,no manual.
AJ
Thanks AJ. I have the track adjuster freed up so I can remove the track. I have a parts and service manual also. if I can get that snap ring out that holds the inner plug I think I can get it out at least I hope so. this can be pulled with out the steering clutch removed according to the manual. thanks norm
