My 60 is leaking hydraulic oil out behind and below the sprocket. It happened while my neighbour was off loading it from his trailer. It still travels fine, does not make any weird noise yet, it just is dumping hydraulic oil out the bottom.
I cant actually see where the oil is coming from...if it is the motor can I just unhook the hydraulic lines and unbolt from the backside? Or do I need to take the track, sprocket final drive etc off first.
Is there a seal between the final drive and the motor? Any advice is appreciated. Thanks, Grant
