VAC CASE PISTON RINGS
Kenny Bill
09-18-2023 14:56:25
I am installing piston rings.. Service manual says to look for a dot or a marking top to install rings right side up. Rings that I have are not marked at all. Can anyone help in determining which side is up.
mEl
09-19-2023 04:57:24
 Re: VAC CASE PISTON RINGS in reply to Kenny Bill, 09-18-2023 14:56:25
Quoting Removed, click Modern View to see As a rule rings not marked are ok either direction, BUT, inspect the rings carefully on the inner and outer ring edges. Rings with a bevel or cut on the inside edge go inside edge uo, if the is a groove cut on one side of the outer ring that would go down.
r.w.b.
09-19-2023 03:24:37
take em back,ask for instruction sheet for the rings.
