Im attempting to revive an 800 diesel COM tractor which has not run in about 15 years. I had it fired up and had no converter or clutch oil PSI, the clutch pedal and COM lever seemed ineffective, and I was able to slip the gear shifter into any gear with no grinding and the tractor would not move. The COM oil level was at the full mark but it seemed the pump isnt moving any oil. I dropped the oil today and cleaned the filter which seemed to have very little debris in it. Could I have an airlock in this pump? Is it possible it just needs to be primed? I noticed on the COM pump housing a small brass petcock, so Im wondering if the pump is weak and needs to be primed or just open the petcock to release an airlock. Anyone else have a similar issue with the COM pump?
Thanks
Richard
Thanks
Richard
