r.w.b.
can you all give me names and phone numbers of people that has
300 400 case used parts.i know ruscha but need others
big 400 the casting at the drawbar frame that holds left eagle hitch arm to chassis/ gear case
All States Ag Parts show having a number of 400's in their salvage yards. 855-530-1460. You need to have the part number or they might send you anything to get a commission.
Don Livingston, much better to deal with, might have your part. 507-433-0073
Goodrich Auction Service 607-642-3293 supposed to have 400 parts.
this is the sprung part
That doesn't look like a 300, it is an older Racine 400. The 300B and 400B were similar tractors, the difference being dry clutch and Case-O-Matic. The 400 is similar to the 700B and 800B, but not remotely close to the 300 round nose.
this is a 411 not a 411b .im needing parts for my 411 and 312 . the piece i posted 3 pictures of is biggest need right now. im wondering if that block is same as 700 and 800 tractors? ive spotted 1 off a 800
The casting number for a 700B/800b is A9189 and is called a bracket - draft arm pivot. This is for a general purpose tractor which you have. Other numbers are for a standard type and high clearance type.
Check the casting number on your bracket to see if it matches and/or use it to find the correct one.
thank you and yes same numbers.i got it ordered from a person.sorry so slow getting back but got tied up last nite. but thank you a lot great information and help
