A44499 Part help needed
Brokengun
After my original Case 1370 Turbo Charger decided to come apart; I purchased a New turbo charger from a known online seller, that also has a Ebay Store. I have purchased from this seller before with NO issues, So i thought everything was going to be good.
The Turbo in question is made by A&I.
The issue I am having is its got a horribly Undersized Air intake that is also too short. Original turbo Air intake nipple for the turbo is 3 inch . The one i was sent is closer to 2-1/2 No way to could be used for a case with a 504 BDT engine
All of the part numbers match up but the Turbo is wrong. I don't know if the turbo was assembled using the wrong outer cover or that its simply mislabeled.
I plan on calling the Seller Monday morning but If can not get the correct part I need a source for a NEW affordable turbo Charger. I paid $359 for the Turbo charger.
The part number they sent is A48192 but is also A44499 or A157336
Thank you for the link If the pictures is correct it looks like the right one.
I don't know what i was sent but its not the right turbocharger for a 1370 case with a 504
I have used the A+I turbo's already and have had no issues with correct fit. I am sure they can get you the correct one, Rod.
