opps bad part on my 400
r.w.b.
was going over my new 400{411} discovered the block on the left hand eagle hitch arm is sprung. id say pulling a heavy load n right link unhooked. i loosened the bolts got pin back in drawbar frame n tightened em but the left lower arm sets out about 4-5 too wide. was thinking heat n bend but after its sprung it might want to go back where it was sprung to if conditions are right.
where is good sources to buy a replacement block used at?
