I posted a few weeks about the PTO on my 1030. It would run implements even though it was disengaged and you could not pull the clutch lever up and engage it. W
I'm not doing the work on the tractor. The PTO linkage was ok. A clutch disc had not broken and doubled up either. Rather the nut holding the clutch pack together let everything slip on the shaft and basically parts became welded to the shaft. I realize I'm not explaining it well.
I'm looking at this point for the parts to switch it over to a 540 rpm out of a 930. Does anyone know where these might be available?
