Anybody have experience removing the clutch on a 1210 tractor?
I need to replace the drive clutch and PTO clutch on this tractor.
It is equipped with the Laycock duel clutch. In the I&T service manual,
for removing the clutch, instructions say to Remove cover at bottom of
clutch and install retaining clips (available at J I Case) over each PTO
release lever, or if desired, wire can be used.
So, if using wire, what is the objective for the levers, is it to hold
them in or out? Right now there is play between the engagement thrust plate
mechanism and the 3 PTO release levers on the clutch. Also looking at the
clutch I don't see any place to put the wire.
The other issue I have is, the manual says the PTO unit needs to be removed.
Instructions are to Unbolt drawbar from PTO, then remove PTO unit and pull
PTO shaft rearward until it clears clutch.
I don't see anything from this repair manual or the Case IH parts web page
that gives a description for a PTO drawbar.
Any help would be appreciated
Thanks
Gortex
Thanks
Gortex
