Torque specs
brentb
Can anyone tell me where I can find the torque specs for the flywheel and also the specs for the pressure plate to flywheel for a David brown 1390. I have the shop manual and cant find nothing there. Thanks
I haven't seen it published anywhere. The flywheel nuts are 7/16 fine, I usually go to 50 foot pounds, then make sure the locking tabs are bent over well.
The clutch cover bolts are 3/8 NC, 30ftpds is probably fine, I never torqued them, just a bump from the impact then check for tightness. I always use new grade 8 lock washers on them.
