Thanks everyone that is willing to help.
I am new to owning a tractor and cant say I understand all terminology, so bare with me.
As far as I can tell it is a 1965 model 32 case 530CK
1. Does this tractor have a torque converter? Is this it in the pic?
2. I have looked in every manual I can find, it show a torque filter should be in front of the radiator but its not on this tractor and I don't see any evidence that it ever was. Someone posted this "My 530D the fill is next to the hyd. valve
/filter housing on top of the trans under the dash on brake side. 1 1/2 " plug" Does anyone have a picture, I sure cant find that.
3. When filling the Torque converter with oil can I use the tube breather and not the dipstick. Its so small and will take forever with 4 gallons or so.
4. Is this a dual or triple range tractor, not that I actually understand what that means yet
5. On the shifter, I can only get it to go into 1st and 2nd. 3rd and 4th, don't seem to be there. Is there a trick with the shuttle or should I be able to shift normal to 3rd and 4th? How do you use the shuttle also, is that clutch in push shuttle then change gears? - little lost on procedure.
6. How do I tell if its a Dry or wet clutch
7. I do not see a replaceable air filter location on this model
Thanks again for any
Mike
working on shrinking photos for upload
This post was edited by msperano on 01/14/2022 at 04:54 pm.
Mike
