Case 1370 hydraulic problems
Otter44
New User
Hey guys I got a Case 1370, we are only getting 500 psi at idle and 700psi full throttle. Readings are equal whether hot or cold. They are also equal on both remotes. All other functions work as they should, 3 point, P/S and PTO. We get no fluctuation in readings sitting at in park running remotes; running remotes with PTO engaged. Readings remain the same using P/S and also with creeper petal engaged or disengaged. We shimmed the relief valve, this also did not improve pressure at all. Any help or suggestions would be appreciated.
Thank you.
