Company Logo (800) 853-2651 Shop Now
Case 530 Questions with Pictures
msperano
01-14-2022 15:52:00
Thanks everyone that is willing to help.
I am new to owning a tractor and cant say I understand all terminology, so bare with me.
As far as I can tell it is a 1965 model 32 case 530CK
1. Does this tractor have a torque converter? Is this it in the pic?
2. I have looked in every manual I can find, it show a torque filter should be in front of the radiator but its not on this tractor and I don't see any evidence that it ever was. Someone posted this "My 530D the fill is next to the hyd. valve
/filter housing on top of the trans under the dash on brake side. 1 1/2 " plug" Does anyone have a picture, I sure cant find that.
3. When filling the Torque converter with oil can I use the tube breather and not the dipstick. Its so small and will take forever with 4 gallons or so.
4. Is this a dual or triple range tractor, not that I actually understand what that means yet
5. On the shifter, I can only get it to go into 1st and 2nd. 3rd and 4th, don't seem to be there. Is there a trick with the shuttle or should I be able to shift normal to 3rd and 4th? How do you use the shuttle also, is that clutch in push shuttle then change gears? - little lost on procedure.
6. How do I tell if its a Dry or wet clutch
7. I do not see a replaceable air filter location on this model
Thanks again for any
Mike
working on shrinking photos for upload
This post was edited by msperano on 01/14/2022 at 04:54 pm.
Joe (Wa)
01-17-2022 10:00:49
 Re: Case 530 Questions with Pictures in reply to msperano, 01-14-2022 15:52:00
No, not hand clutch. Long lever on the left is shuttle.
Joe
muleman51
01-17-2022 06:40:06
Is that a hand clutch tractor?
mEl
01-15-2022 06:04:22
It is a dry clutch so nothing about the TC tractors applies, the lever by the picture of the battery is a HI/lo range selector, The air cleaner is a wet cleaner , you remove and clean the bowl above the engine, refill the bowl to level and reinstall. the plug above and in front of the clutch pedal is the level plug for the manual shuttle and dual range box, the large flat big nut between the shifter cover and the rear cover plate is the rear oil level, (90 weight is good for there). Case Hy Tran wouold be the recommended oil for the front and yes it can be filled through the vent tube. BTDT
Today's Featured Article - Welding Basics - by Curtis Von Fange. One of the most useful skills that an owner of older equipment can have is the knowledge and ability to weld. It seems like the older equipment can do a job, albeit slowly compared to newer stuff, but it tends to break more often. Many of the breakdowns are related to the implements that are being used: the disc, wagon or bushog are among them. Knowing how to fix stress cracks, reinforce weak joints by welding on steel support plates, or cutting and shaping parts and adapters out of raw stee ... [Read Article]
Latest Ad: Minneapolis Moline G. On LP. 403 engine turns over, with some tinkering would run. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
