Company Logo (800) 853-2651 Shop Now
Case Model 930 (940 Gasoline engine)..
John Deere D
01-14-2022 08:48:52
I own a case Model 930 (940 Gasoline engine)....
I have located and ordered an original Parts Book.......:)
My question is......
I was informed the CASE 900 also had a Gasoline engine....????
I require the component that the Engine Tachometer cable attaches to... (below Distributor drive) I have located such from a Case 900.
I also require the Engine Tachometer. And flex Cabel drive..
Would the Case 900 Gasoline Engine have the same Engine Tachometer.? And flex Cabel drive?
I'm wintering in Arizona..
Thanks
Bob..
RGMartin
01-14-2022 10:42:43
 Re: Case Model 930 (940 Gasoline engine).. in reply to John Deere D, 01-14-2022 08:48:52
900s were diesel, 910s were propane(which would have spark ignition like a gas), no gasoline version that I know of.
The diesel tach should be fine.
John Deere D
01-14-2022 14:23:37
 Re: Case Model 930 (940 Gasoline engine).. in reply to RGMartin, 01-14-2022 10:42:43
Thank you Sir
Bob..
John Deere D
01-14-2022 09:38:31
I also have access to a NOS Engine Tachometer from a CASE 930 Diesel.....
Will this Tachometer work properly on my Case 930 with the 377 Gasoline ENGINE????
Thank You
Bob..
chuck machinist
01-14-2022 13:50:57
 Re: Case Model 930 (940 Gasoline engine).. in reply to John Deere D, 01-14-2022 09:38:31
The diesel and propane blocks were 377 cubic inches. Stroke on both were 4x 5. You are safe to use that cable, as RG has mentioned CM
John Deere D
01-14-2022 14:24:12
 Re: Case Model 930 (940 Gasoline engine).. in reply to chuck machinist, 01-14-2022 13:50:57
Thank you Sir:
Bob..
Today's Featured Article - Talk of the Town: Trailerin a Tractor, Chains or Straps? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: " I bought a trailer and plan to take my CASE VAS to some shows. I don't yet have anything to secure it to the trailer. So which is better to buy and use; the ratchet-type straps or binders and binder chains? ... [Read Article]
Latest Ad: Massey Harris 44 with widefront,power steering and cab. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
