1175 puller
I have a few questions about setting up a 1175 for pulling. It will be running in a 3000 rpm class, 10 & 14 mph. We are swapping engines out for a 504. The 504 came out of a powershift tractor. Can I use that flywheel or the 451 flywheel or find a 504 flywheel out of a 8 speed tractor? Also the clutch setup. The powershift clutch looks like a double clutch. Can I adapt that to the 8 speed in the 1175? I already know the clutch in it now wont hold. Any information on this will be greatly appreciated. Not much info out there on Case pullers.
The motor will fit just fine, the 451 flywheel and clutch will work also, if your worried about it slipping, call Karl at Atlas tractor and get 1 of his 2 disc clutch assembly, It won't be cheap, but it will work and hold all the power you will make with a stock engine and stock head gaskets, because i'm sure your gonna blow gaskets
I am having fire rings installed. I am lucky to have a person in the neighborhood that pulls on the national level. He pulls IH put knows engine building. Not worried about the engine. Just clutch an flywheel
