930 ck power steering
1974vette
Good morning all. My 930 steering squeels a lot. The pulley on the water pump has a ridge worn into it from belt slippage. I got a pulley off a 930 parts tractor but Is larger. Original pulley is 45/8
New replacement is 53/4. Would the larger pulley be better if spin faster or actually make it worse?
Thanks
Hi:
I was taught that the bigger on the receiving end the slower the spin and smaller would be faster. The opposite is true for the sending end. So your power steering pump would now turn slower.
The pulley that I need to change is on the fan(driver) not
touching the pulley on the actual pump.(receiver). So would
faster be better or worse?
Make sure the other belts will fit too. There e st least 3 different belt configurations on the 30 series. Two run 2 belts from crank to water pump and alternator with a separate power steering belt. The last ones had just 2 belts.
As far as speed, that much extra won't hurt. Those are the same pumps used on Ford cars and trucks of the time and they can run much faster.
