David Brown 770A aux. hydraulics
kusant
New User
I'm working on a David Brown 770A, and it has an aux hydraulic valve? on the front of the rear axle on the left hand side. It leaks from a valve knob when running. I can't find any information on this. Can somebody help?
Its called a " 3 way valve" that should get you headed in the right direction.
Basically you pull your 3 point lever all the way back and it gives you some remote hydraulic capability.
